1993 BMW 325 Acceleration and car dieing off.
RAKABN
  • 1993 BMW 325
  • 6 CYL
  • FWD
  • 180,000 MILES
I Have been working on this car for awhile now, It recently had a major oil leak on the spark plugs and I have replaced the crank position sensor and oil filter. But now my car while accelerating I hold the gas down and it ether stops completely like it had died and then starts back up again or while in Idle I push the gas for a second and I let go of the gas and the gas pedal keeps Reving itself without my doing, I have been told the fuel pump may be dieing, But it sounds like it is running perfectly.
Wednesday, June 16th, 2010 AT 4:58 PM
DOCHAGERTY
  • 9,601 POSTS
What was the reasoning for the replacement of the position sensor? It sounds like it has developed an intake manifold leak.
Thursday, June 17th, 2010 AT 8:22 AM
RAKABN
After the oil leak in the spark plug tubes the car would not start, My coils were not getting any power I was told this was a normal problem withe position sensor after replaceing my car did start right up.
Thursday, June 17th, 2010 AT 8:41 AM
DOCHAGERTY
  • 9,601 POSTS
Thank you. The possibility of the fuel pump as the driveability problem is certainly high, check the fuel pump delivery and pressure.
Thursday, June 17th, 2010 AT 9:07 AM
