1985 BMW 325 engine stall when warmed up
1985 BMW 325
22,500 MILES • 6 CYL • 2WD • MANUAL
LIJAYNOEL1234
this car runs great when stated in the morning but as the engine warms to around 150 degrees it stalls and sputters when the accelerator is dpressed. the coolant temp sensor has beed replaced. mass air flow has been replaced. tps has been replaced. and it still does the same thing also pump pressure and regulator has been verified. please help
Jun 30, 2010 at 11:24 PM
DOCHAGERTY
  • 9,606 POSTS
For verification purposes, may I get the VIN?
Jul 1, 2010 at 2:03 AM
LIJAYNOEL1234
its acting like the coolant temp sensor but i have replaced it will idle hot starts funny hot but will spit and spudder when hot like the fuel mix is off when hot. no visable black smoke and somewhat lean smell
also check engine light is lit most of the time but sometimes goes out (consant flash)
Jul 1, 2010 at 2:13 AM
DOCHAGERTY
  • 9,606 POSTS
You may wish to have another look at my request.
Jul 2, 2010 at 12:59 AM
LIJAYNOEL1234
WBAAB5406F9627728 i put it in the sublect line last time but i dont see it know thanks
Jul 2, 2010 at 1:03 AM
DOCHAGERTY
  • 9,606 POSTS
One more thing, 1985 BMW cars did not have a check engine light at all.
Jul 2, 2010 at 1:50 AM
LIJAYNOEL1234
well this has a check light right above the inspection indicator
Jul 2, 2010 at 1:54 AM
DOCHAGERTY
  • 9,606 POSTS
That isn't a check engine light, it is a check control for lamp functionality, coolant level, engine oil level, etc. The particular indicator will be in print and illuminated and will cause the check control lamp to flash. The flahing lamp can be extinguished by pressing the black button on the check control panel.
Jul 2, 2010 at 2:22 AM
DOCHAGERTY
  • 9,606 POSTS
There might be some leaky injectors at the mileage reported. 225 thousand miles, correct?
Jul 2, 2010 at 2:53 AM
