1992 BMW 325 Hydraulic Clutch gone limb...
1992 BMW 325
155,000 MILES • 6 CYL • 2WD • MANUAL
DGREEK
What can I do to diagnose and fix the clutch problem? It suddenly went limb and does not actuate the clutch. It just goes to the floor. It does return, so the springs on it seem to still work, but no friction and no clutch dissengangement - kind of like the fluid in the hydraulics is gone! A bit like when you need to bleed your brakes.
Apr 2, 2009 at 9:07 AM
DOCHAGERTY
  • 9,606 POSTS
Replace the clutch master and slave cylinders and bleed the system, failure of the clutch hydraulics at that mileage is quite common.
Apr 2, 2009 at 10:03 AM
