I need to replace the drivers side power steering rack boot. It appears that I will need to remove the tie rod end. How is the boot removed?
Jul 2, 2008 at 2:33 AM
DOCHAGERTY
✓Experienced Mechanic
Get a strong pair of diagonal cutters and cut the metal clips off and then remove the boot. I replace the metal clips with black plastic zip ties. Hope this gives you what you need mate.
Jul 2, 2008 at 3:22 AM
