1992 BMW 325 gas gauge, coolant gauge, radio, info computer
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
DELONUGGS
So my car suffered having the battery hooked up backwards for a sec. Shot sparks. So now the fuel gauge, coolant gauge, radio, and info computer are not working. and the windows and sunroof only work when the door is open. This sounds like a computer module to me as I replaced all of the smaller fuses. But theres also relays and such. First are there any other fuses than ones under hood? Second do you think relay or computer? If computer which one?
Jan 12, 2010 at 12:43 PM
2 CARVINCE
  • 31 POSTS
there are several things that it could be but first,there's a circuit board in the instrument cluster that controls the service indicator lights , which also back feeds coolant gauge and fuel.try that first , let me know what you find/
Jan 21, 2010 at 10:06 AM
DELONUGGS
I have come to find out that the wipers are out as well. All of my cluster indicator lights work. Those things combined with the windows only working when door is open make me think relay or multiple problems. If you still think I need to check that board, how exactly should i go about that. Should I check that it is getting power, cause I assume it is or the indicator lights wouldnt work. I wish I knew all the relay locations and how to test them. I feel it prob will be multiple issues. windows, wipers, gauges(mph and rpm work fine) , radio, its like half the car is down. Thank you by the way for your reply. If I can save going to bmw shop, you can expect a nice donation in your future.
Jan 21, 2010 at 12:01 PM
