1992 BMW 325 dash lights
1992 BMW 325
218,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAX1391
the dash lights keep going out, i took out cluster change bulbs they worked fine for a couple of weeks, i took them out cleaned connections, worked for awhile. you can unplug the cluster then reconnect they will work again. any ideas?
May 18, 2009 at 1:31 PM
DOCHAGERTY
  • 9,606 POSTS
The lights are fused, check the fuses and replace any dark bulbs.
May 23, 2009 at 3:38 PM
