1992 BMW 325 blower motor
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
KGARRETT5
My blower is not running when I turn the switch on at all. The fuse to the motor blows out when I turn on the blower in the car, I have replaced it twice. Is this most likely the blower motor?
Aug 30, 2009 at 8:16 AM
  • 75,988 POSTS
Power the blower motor direct from the battery with an inline fuse-if the fuse blows its the blower motor if not-troubleshoot the blower motor circuit unable to bring it in to the pros-
Aug 30, 2009 at 8:21 AM
DOCHAGERTY
  • 9,606 POSTS
If it is the blower motor, be warned, it is not an easy job. And be sure they sell you the replacement motor with squirrel cages that come off the ends of the shaft, you have to be able to fit the squirrel cages together inside the heater box, there isn't another way unless the entire heater box comes out.
Aug 30, 2009 at 2:52 PM
