1991 BMW 325 Very hard cold start
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHICKLIS
I have changed the mass air sensor,new plugs and new fuel filter. First time to crank in the mornings it fires right up then shuts off and will not crank unless you disconnect the mass air box for a few seconds. Replug the mass sensor and after it warms up runs and goes great..no smoking either......What the heck. Thanks.. Shannon
843 450 1430
Dec 18, 2009 at 10:40 AM
RACEFAN966
  • 5,029 POSTS
Ok so first tell me is the check engine light on? If so did you pull codes?
Dec 19, 2009 at 1:38 AM
DOCHAGERTY
  • 9,606 POSTS
Shannon, you call me back if there's anything else you need.
Dec 19, 2009 at 3:33 AM
CHICKLIS
First ,let me thank all that helped me with answers about this problem. I did not have a reader for the BMW because it takes more than one style. But with the help of "'The Dr." he took me step by step to check many things that could have been tied to the problem. Come to find out....I over looked the conection at the thermostat housing and found a conection that had come loose just like he told me. I HIGHLY recommend these guys on this site and if I need help again will not hesitate to ask ..
Again,THANK YOU !!!!! If you ever make it to Myrtle Beach look me up !! Shannon Currie/Myrtle Beach SC
www.Catch-1familyfun.com
Dec 19, 2009 at 6:26 AM
RACEFAN966
  • 5,029 POSTS
Well may I say for both of us you are very welcome. I am glad you were able to find the problem and fix it. Thanks Dr. you did what I couldn't.
Dec 21, 2009 at 4:56 AM
