1989 BMW 325is coupe oil pan removal
MSPAINTER
Is it necessary to raise the motor on an '89 BMW 325is in order to remove the oil pan? The chilton manual I have for it says that it may be necessary to do this on SOME models. I would like to know though, Is it necessary on MY car?
Aug 18, 2007 at 8:27 PM
  • 75,988 POSTS
[quote:a42c6bd407="mspainter"]Is it necessary to raise the motor on an '89 BMW 325is in order to remove the oil pan? The chilton manual I have for it says that it may be necessary to do this on SOME models. I would like to know though, Is it necessary on MY car?[/quote:a42c6bd407]
My book for your model says you have to- then again my book might be lying to me. anything is possible-
it also says to remove the starter and some steering components.
Good luck
Aug 18, 2007 at 11:18 PM
DOCHAGERTY
  • 9,606 POSTS
I usually lower the subframe and support the motor from the top, it's easier this way.
Aug 19, 2007 at 4:17 AM
