1989 BMW 325 Turn Signal Relay
1989 BMW 325
16,000 MILES • 6 CYL • 2WD • MANUAL
STEPHEN89325I
A couple of days ago my Right Turn Signal stopped working. Left one works with front and rear flashers working. The right bulbs to F and R have been checked and are working. When using turn signal right, it buzzes with no flashes on cluster. Also Hazzard switch buzzes when pressed in (also with no flashes on cluster and light bulbs) As these are connected together. I replaced turn signal switch w/Hella relay twice from a pick a part . And it still buzzes. I even took the relay and put it in my friends 88 325ix and it worked but it doesn't on mine. Any suggestions ?
Dec 7, 2009 at 7:39 AM
DOCHAGERTY
  • 9,606 POSTS
It could be the turn signal switch or a bad ground or a bad bulb. Check the grounds and wiggle the wires/switches/bulb holders.
Dec 8, 2009 at 12:54 AM
