There could be an issue with the connector for the injection harness. It is directly under the throttle body and it is a round black connector. This connector needs to be inspected for corrosion. It was a problem with a lot of these M-20 I motor cars. Sometimes you can clean the connector, sometimes you have to cut the corroded parts out and hard wire it.
SPONSORED LINKS
Saturday, March 21st, 2009 AT 12:08 PM
