i resently took my 89 bmw apart to change the gaskets on it and replaced the mass air flow sensor on it but when to turn it on i need to disconect my sensor nd when its on and i try to connect it back on i stalls i can run it without the sensor but then it idles really high and than when i put it in gear it kinda bogs then it takes off what can i do should i check my fuel pressure change my fuel pressure regulator?
Jan 12, 2009 at 9:34 AM
