1989 BMW 325 fuel pressure
1989 BMW 325
152,000 MILES • 6 CYL • 2WD • MANUAL
89BIMMER
i resently took my 89 bmw apart to change the gaskets on it and replaced the mass air flow sensor on it but when to turn it on i need to disconect my sensor nd when its on and i try to connect it back on i stalls i can run it without the sensor but then it idles really high and than when i put it in gear it kinda bogs then it takes off what can i do should i check my fuel pressure change my fuel pressure regulator?
Jan 12, 2009 at 9:34 AM
DOCHAGERTY
  • 9,606 POSTS
When apart, which gaskets did you replace? Why did you replace the air flow meter, was it bad? Have you tested the fuel pressure?
Jan 12, 2009 at 12:20 PM
89BIMMER
no i havent check my pressure because im not exactly sure how to do it..i replaced all of my gaskets and yes i replaced the air flow meter because it was bad.. how would i check my fuel pressure
Jan 13, 2009 at 11:26 AM
DOCHAGERTY
  • 9,606 POSTS
There is about 50 psi of fuel pressure in the feed line, open that line and introduce your gauge, not the line returning fuel to the tank. It should read 3.0 bar at idle with the vacuum line removed from the fuel pressure regulator.
Jan 14, 2009 at 3:06 AM
