1989 BMW 325 Car wont start, not the crank sensor, not cap/
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
AISHITERU_GRAPES
My car stalled/died on the freeway right after I got on. It was a hot day, but it's never died on me before. Here's what happened, I had slowed down then car stalled when trying to accelerate again. Was able to steer to the shoulder, but then car wouldn't start again. This was one week ago. I have changed the crank sensor, cap and rotor, fuel pump's pumping, coil is working, crank is moving, but still my car won't start. Does try, but no turn over. What do I do? I miss having my car. I feel like I'm running out of options. I've had my car for 2 years now, but this one stumps me.
Apr 29, 2009 at 5:19 PM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 29, 2009 at 5:25 PM
AISHITERU_GRAPES
Thank you for the reply. We did try the fuel and it pumped out when cranked, had faint spark at wires, but not at spark plugs. Again, we just bought ignition coil and still no spark.
Apr 30, 2009 at 2:56 AM
DOCHAGERTY
  • 9,606 POSTS
If there is a spark at the coil but not the plugs then the cap/rotor/wires are suspect. Have you investigated this possibility?
Apr 30, 2009 at 4:17 AM
AISHITERU_GRAPES
Have replaced cap and rotor, but I will check on the wires though. That's our last thought right now. I sure hope it works.
Apr 30, 2009 at 12:37 PM
DOCHAGERTY
  • 9,606 POSTS
New spark plug wires and I would install a fresh set of plugs too. Bosch W8LCR is the right plug for that motor, do not try anything else, no super platypus plus power plugs, just the Bosch plug.
Apr 30, 2009 at 4:35 PM
