1988 BMW 325 tire removal
100,000 MILES • 4 CYL • FWD • AUTOMATIC
PESCADOR
Is there a special tool needed to remove the tire? I removed the lug bolts ,but the tire wont budge. It appears to have a lock ring at the center of the rim.
Jun 6, 2008 at 1:46 PM
DOCHAGERTY
  • 9,606 POSTS
If you have removed the lugs and cannot get the wheel loose, you will need to beat the damn thing with a dead blow hammer to get it off. There is electrolysis between the steel hub and the aluminum alloy wheel and it makes getting wheels that have not been off in a while, or ones that have not been lubed with anti-seize difficult to remove.
Jun 6, 2008 at 5:35 PM
