1987 BMW 325 Washer hose tee
1987 BMW 325
GDIZZIE
1987 BMW 325 6 cyl Manual
My washer hose tee connector has two holes on the top. I'm not sure if the previous owner did this or if this is normal but should it be replaced? Everytime i run the washer fluid it sprays out of the holes instead of to my washer nozzles.
Sep 6, 2010 at 2:29 PM
  • 31,937 POSTS
Hi there,
if you block off the open "T" do both nozzles work? i think one nozzle hose may have come off , check around the fitting it may be there to be plugged back on.
Mark (mhpautos)
Sep 6, 2010 at 2:34 PM
GDIZZIE
No, The hose running from my reservoir is fine and plugged in. Also both nozzles hoses are fine and plugged in, but there are 2 other small holes on the top of the "T" that sprays fluid onto my hood. There is no way to plug these holes and all of the connections are fine.
Sep 6, 2010 at 2:42 PM
  • 31,937 POSTS
Hi there,
I would be thinking that the "T" piece has just fatigued and is cracking, you should be able to get a new fitting from you local dealer, you would hope that they would fit this FOC.
mark (mhpautos)
Sep 6, 2010 at 11:43 PM
