1987 BMW 325 spark plug blow out
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANKYBOY
when cheking the car after ive notice something wrong with the engine i notice that a spark plug was ejected trying to putting it back it was like it dindt belong there why would that happend?
Jan 1, 2008 at 9:33 AM
BLACKOP555
  • 10,386 POSTS
first thing i always do is look at the plug, if the ceramic is broken or the electrode tip is broken then i know it was hit by a piston and i would have to probably rethread the heads and take a look at the piston, if theres no damage to the spark plug or head it probably wasnt installed tight enough.
Jan 1, 2008 at 9:55 AM
FRANKYBOY
im sure you are right because ive called some mechanics in the last hour and they said the same thing like you that probably it wasnt inseted right right now a BMW mechanic from the family is going to come to my house ill writte you back to let you know what it was altough im 99% percent sure you are right, one thing to add is that this guy changed the head like a month a go probably it has something to do with it.... and one more question does the past that you are supposed to add to the spark plug befor you assemble it back works?? is it essential to pu it??
Jan 1, 2008 at 10:04 AM
BLACKOP555
  • 10,386 POSTS
you dont have to, but its always safe then sorry! and when the guy changed the head and he stripped out the spark plug or bumped it loose.
Jan 1, 2008 at 12:05 PM
BLACKOP555
  • 10,386 POSTS
hope you find your problem!
FRANKYBOY
you were right u sure know what u are talking about man thans very much!!!!!!!
Jan 1, 2008 at 8:12 PM
BLACKOP555
  • 10,386 POSTS
thank you very much for the complement :D
Jan 2, 2008 at 1:27 AM
