1987 BMW 325 broken speedometer
1987 BMW 325
25,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUTH82
I thought it was a blow fuse but have replace it with new ones, I know i can fixed it but have no idea what i am looking for.. help
Apr 3, 2008 at 11:03 AM
DOCHAGERTY
  • 9,606 POSTS
I am unsure of your question. Do you have a problem with the instrument cluster? Is the speedometer not working? If the speedo is the issue then you may have a problem with the driver chip in the speedo. Replacement or repair is a possibility. Please repost if more assistance is needed. Dr. Hagerty
Apr 3, 2008 at 1:20 PM
RUTH82
the speedo just stop working. I thought it was a fuse but I replace them with all new ones.
Apr 4, 2008 at 6:09 AM
DOCHAGERTY
  • 9,606 POSTS
Thanks for your response. It certainly seems like the speedo driver chip from here, I recommend removing the instrument cluster and inspecting the unit after disassembly. It is likely that the driver in the speedo has failed, I also request inspection of the service interval board(the one with the batteries attached) As stated earlier, replacement of the cluster might be an easier way to address this issue, if so, a salvage yard might be a suggestion that would help. Call Autobahn dismantling @ (619)444-2290 and speak to either John or Sean. Tell them I sent you.
Apr 4, 2008 at 7:25 AM
