1987 BMW 325
192,000 MILES • 6 CYL • 2WD • MANUAL
BRETWEIR
what is the correct idle at neutral?
Mar 13, 2010 at 6:00 AM
DOCHAGERTY
  • 9,606 POSTS
It should be on the under hood emissions sticker.
Mar 13, 2010 at 8:22 AM
DR LOOT
  • 2,311 POSTS
Is it an "i" or an "e"?
Mar 14, 2010 at 8:27 PM
BRETWEIR
neither, it is a straight 325
Mar 15, 2010 at 12:42 AM
DR LOOT
  • 2,311 POSTS
[quote:c02e07f210="bretweir"]neither, it is a straight 325[/quote:c02e07f210]
OK, I'm pretty sure that model is an "e". The easy way to tell is to look at your tach. If the redline is 4500 rpm, then it's an "e". If it's 6500, then it's an "i".
Mar 17, 2010 at 8:05 AM
BRETWEIR
redline is at 4500 so i guess its a 325e
Mar 18, 2010 at 9:20 AM
DR LOOT
  • 2,311 POSTS
Idle speed and fast idle speed are controlled by an idle speed control unit. Connect dwell/tachometer to engine. Check idle speed. If specification is not correct, check idle speed control unit and replace if required.
IDLE SPEED SPECIFICATIONS Application RPM All Models 650-750 rpm
Mar 18, 2010 at 10:55 AM
