[quote:c02e07f210="bretweir"]neither, it is a straight 325[/quote:c02e07f210]
OK, I'm pretty sure that model is an "e". The easy way to tell is to look at your tach. If the redline is 4500 rpm, then it's an "e". If it's 6500, then it's an "i".
Mar 17, 2010 at 8:05 AM
BRETWEIR
MEMBER
redline is at 4500 so i guess its a 325e
Mar 18, 2010 at 9:20 AM
DR LOOT
✓Experienced Mechanic
Idle speed and fast idle speed are controlled by an idle speed control unit. Connect dwell/tachometer to engine. Check idle speed. If specification is not correct, check idle speed control unit and replace if required.
IDLE SPEED SPECIFICATIONS Application RPM All Models 650-750 rpm
