1987 BMW 325
MOGIRL12
Engine Performance problem
1987 BMW 325 6 cyl Manual 200000 miles
When I start my car in the morning I drive about 2 miles the temperature gauge rises and the engine begins to cut out. I stop and shut the ignition switch off and immediately restart the car the temperature gauge drops to a normal position and the car runs fine. In the afternoon this activity may or may not happen. If it does not correct itself the first time I restart the engine I keep trying and within a few times it corrects itself and I have power to drive to work about 30 miles. It is not overheating as the water temperature is normal. I have changed the oxygen sensor.
Aug 27, 2009 at 2:21 PM
DOCHAGERTY
  • 9,606 POSTS
Please repost with the last 7 of the vin. so I can ID the car, thanks ♥
Aug 28, 2009 at 1:39 AM
MOGIRL12
Last 7 digits of my vin number are 1925126
Sep 9, 2009 at 12:14 PM
DOCHAGERTY
  • 9,606 POSTS
There is a wiring connector several inches in front of the starter that gets corroded, can you find it?
Sep 9, 2009 at 5:27 PM
