1987 BMW 325
345,000 MILES • 6 CYL • 2WD • MANUAL
PAPAGRAMMY
A/C fuse blew. Replaced and Blew again. Replaced and this time did not blow, but no cold air. Checked A/C compressor and the magnetic clutch will not engauge when A/C button on dash is pressed. Blower works. I see what appears to be a diode on the Compressor. How do you test the magnetic clutch and or diode without removing the compressor? I would like to troubleshoot the problem without taking everything apart. The A/C was working fine, putting out plenty of cold air and running on a long trip for over and hour when it died.
If the wires going to the compressor need to be removed for the test, how do they detach. It is dark down there and I can't see them that well. I just don't want to pull on them and break them. If the clutch is to be removed, how do you do it without disconnecting all the hoses and loosiing the R-12?
Jul 3, 2008 at 5:48 PM
DOCHAGERTY
  • 9,606 POSTS
The connector to the magnetic clutch is easily disconnected by just pulling them apart. You can then apply battery voltage to the clutch and observe it's function. If the clutch has failed it can be removed while the compressor is still installed, it will require a special puller.
Jul 4, 2008 at 12:42 AM
