1986 BMW 325 I HAVE A BROKEN PULL CABLE THAT OPENS THE HOOD
1986 BMW 325
96,000 MILES • 6 CYL • 2WD • MANUAL
JOURNEYQUEST
THE CABLE THAT OPENS THE HOOD, BROKE RIGHT AT THE LEVER ONE WOULD PULL TO OPEN THE HOOD.
THERE IS A LITTLE BIT OF THE CABLE THERE. I USED A VICE GRIP AND TRIED TO OPEN IT BY PULLING ON THE CABLE. IT WOULD NOT OPEN THIS WAY. I PULLED VERY HARD, AND STILL NOTHING HAPPENED.
I NEED TO OPEN THE HOOD TO CHARGE THE BATTARY BEFORE I CAN START THE CAR. I ALSO NEED TO REPAIR THE CABLE.
PLEASE TELL ME HOW I CAN MAKE THIS WORK?
THANK YOU,
GREG WILLIAMS
GREGERY03@AOL.COM
707-448-8722
Oct 21, 2009 at 8:32 AM
DOCHAGERTY
  • 9,606 POSTS
The battery is in the trunk. The release catch is behind the left grill, I have had some luck getting the hood open by removing the left grill and operating the release from there. If there is a bit of cable that is still sticking out, put the vice-grips back on and pull like you're mad at it.
Oct 22, 2009 at 12:20 AM
DR LOOT
  • 2,311 POSTS
Take a long regular screwdriver with a medium tip. You can stick it through the grill about three inches to the inside of the driver's side high beam and find there a slot in the latch mechanism. Stick the screwdriver in the slot and turn it clockwise, and the hood will release. You'll probably need a flashlight to see the slot.
Good Luck.
Dr. Loot's Assistant
Oct 26, 2009 at 3:35 PM
