1986 BMW 325 how to set the timing
1986 BMW 325
EDBAGS1
Engine Mechanical problem
1986 BMW 325 6 cyl Two Wheel Drive Manual
i put a new head on it how do i set the timing before i put the timing belt on
Apr 10, 2009 at 4:28 AM
DOCHAGERTY
  • 9,606 POSTS
Cam timing is set by lining up the timing marks on the cam belt pulley and the mark on the cylinder head whilst the #1 cylinder is at TDC. You should be able to see them at about the 4 o`clock position at the head, just by the alignment dowel.
Apr 10, 2009 at 5:23 AM
