1986 BMW 325 Fuel pump
1986 BMW 325
86,000 MILES • 4 CYL • 2WD • MANUAL
DIANA0115
I just had a new pressure plate, throw out bearing, clutch and transmission put in my car. The motor ran fine until then. Now the in line fuel pump will not come on. There is no power getting to it when checked with a power tester. The fuse box has no power on fuse 11 either. I change the relays and still no power. Help please.
May 18, 2008 at 3:12 AM
DOCHAGERTY
  • 9,606 POSTS
The fuel pump relay will get it's power from the main relay, did you replace the main relay too?
May 19, 2008 at 6:06 PM
