1986 BMW 325 clutch
1986 BMW 325
218,000 MILES • 6 CYL • 2WD • MANUAL
RACERDOUG
I'm sure the pressure plate & disc is fine but over time the pedal doesn't release the clutch enough to shift easily. I saw no leakage at the slave cylinder. The pedal had more and more free play. Under the dash I noted the pedal return spring assy. was falling apart (due to the free play?). I removed the master cyl. and am wondering how I can test it. Where most master cylinders have a place to fill with brake fluid, this one just has a rubber boot/plug with a hole in the top. What do I do next??? When I actuate the rod, nothing comes out of the end that connects to the slave cylinder.
Any help would be greatly appreciated.
Oct 22, 2008 at 5:01 AM
DOCHAGERTY
  • 9,606 POSTS
How do you know the clutch is ok? I would replace the master cylinder and see what happens.
Oct 22, 2008 at 11:40 AM
