1986 BMW 325
I am having a problem with my turn and hazard warning signals. They were working, then started to work occasionally, then they both went out at the same time. I have purchased a turn signal relay from the Auto Parts store and am trying to figure out how to install it in the correct slot inside the fuse box, OR learn more about the installation process if it is needing to be installed inside the steering column itself.
Jun 30, 2008 at 6:22 AM
