BMW 323i Inadequate Heater
JAMESPATON
BMW 323i convertible R reg 112000 miles.
The heater is inadequate.I have replaced the climate control box,with no benefit.
I am about to replace the thermostat.If this does not work,what next?
The temp gauge is just short of midway after 10 minutes warmup.
Nov 4, 2007 at 11:58 PM
DOCHAGERTY
  • 9,606 POSTS
inspect the heater control valves, they may be the cause of the problem.
Nov 6, 2007 at 6:26 AM
Suggested Repair
Inspect the heater control valves, which may be restricting heat even after the climate control box was replaced.
Conversation Summary
The owner of a BMW 323i convertible reports inadequate heater output after replacing the climate control box and plans to replace the thermostat next. After about 10 minutes of warmup, the temperature gauge sits just short of midway. The expert recommends inspecting the heater control valves as a possible cause.
