2000 BMW 323 First Gear Vibration
ALECHICH
my 2000 323 5 speed, no leaks, bought about 1 month ago at a used car lot, 75K miles, will start vibrating at the shift lever and sometimes can feel in rear end when accelerating past about 3000 rpm in first gear (which i hardly ever do, but tried it after a couple weeks of babying it). sometimes does it a bit in 2nd but then will smooth out at higher revs. no problems in higher gears. everything seems tight in the drive train and runs very smooth, even in low rpms in higher gears. any ideas?
Oct 16, 2007 at 6:18 AM
DOCHAGERTY
  • 9,606 POSTS
possibly a drive shaft issue.
inspect for a failed center support bearing
Oct 18, 2007 at 7:17 AM
Suggested Repair
Inspect the driveshaft for a failed center support bearing.
Conversation Summary
A 2000 BMW 323 5-speed with about 75,000 miles and no leaks vibrates at the shift lever, and sometimes in the rear, when accelerating past about 3000 rpm in first gear. It may do this slightly in second before smoothing out, with no issues in higher gears and an otherwise tight, smooth drivetrain. The expert suggested a possible driveshaft problem and recommended inspecting the center support bearing.
