2000 BMW 323 No Reverse
BIOGUY1979
I have a 2000 BMW 323i with 94,000 miles, automatic. Most of the miles have been highway miles. Recently, the car does not reverse. I would put shift it to reverse and the engine just races with no movement. The car moves forward just fine, and there does not seem to be any other problems with the car. The last oil change that I had showed that my fluids were fine, even though it was not reversing. What could be the cause of this? What would be the estimated cost to fix it? Thanks!!
Jul 23, 2007 at 10:59 AM
DOCHAGERTY
  • 9,606 POSTS
the transmission will require replacement. cost for the transmission is about 2500 US dollars for a remanufactured unit.labor to install should not exceed 5 hours.
Jul 26, 2007 at 9:25 PM
Suggested Repair
Replace the automatic transmission with a remanufactured unit. The unit is about $2,500, and installation labor should not exceed 5 hours.
Conversation Summary
The owner of a 2000 BMW 323i automatic with 94,000 mostly highway miles reports that reverse does not engage and the engine races, while forward gears work normally and fluid levels were recently checked as fine. The expert states the transmission requires replacement, estimating about $2,500 for a remanufactured unit and no more than 5 hours of labor.
