2000 BMW 323 Trunk Lid electronic opener doesn't work
2000 BMW 323
85,000 MILES • 6 CYL • 2WD • MANUAL
ALANPARISER
Electric Trunk lid opener ( both key buttons as well as interior console button) stopped functioning at same time. Checked fuses (2 of them), and checked valet switch on trunk key cylinder. All are OK. Also bought a new trunk lid actuator to replace existing one. Still does not work! Trunk can only be opened with key (mechanically). Other door locks all work OK from keys and interior open / lock button.
Is there anything else in the system that can be the problem beside the actuator, fuses and the valet switch?
May 11, 2010 at 7:52 AM
DOCHAGERTY
  • 9,606 POSTS
There is a wiring loom at the right hinge, pull back the accordion boot and inspect the loom. If that passes muster then the next thing is the general module may need repair/replacement.
May 12, 2010 at 3:17 AM
ALANPARISER
[quote:ae164ccfcf="Dr. Hagerty"]There is a wiring loom at the right hinge, pull back the accordion boot and inspect the loom. If that passes muster then the next thing is the general module may need repair/replacement. Check out this site: http://www.bmwgm5.com/
If that dont get it, let me know and we will go forward from there.[/quote:ae164ccfcf]
You are correct. After a bit more investigation, I discovered several broken wires in the accordion boot and after repairing them, the trunk lid works OK. However, now the backup lights don't work (!) so I suspect there are some more wires to fix. Thanks. AP
Jun 1, 2010 at 10:09 PM
DOCHAGERTY
  • 9,606 POSTS
Another correct diagnostic from the doctor!
Jun 3, 2010 at 2:00 AM
