2000 BMW 323 testing spark and injector pulse
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAGER
2000 323i won't start. I have replaced the fuel, I have fuel pressure, and compression. How do I test for spark at the coil, and injector pulse?
Jun 11, 2008 at 6:28 AM
DOCHAGERTY
  • 9,606 POSTS
Pull a spark plug and attach the coil and see if there is spark would be one way. If you don't have spark or fuel there is a possibility there is something that has set a fault and can be read out with the proprietary BMW software. The drive away protection called EWS may be out of alignment and will require a trip to an agency with the correct software to remedy this issue.
Jun 11, 2008 at 7:03 AM
