2000 BMW 323 reverse
CHRIS154
Transmission problem
2000 BMW 323 6 cyl Two Wheel Drive Automatic
is there a part that can be changed out when the reverson the transmission goes out r does the entire transmission have to be replaced
Apr 26, 2009 at 10:29 AM
DOCHAGERTY
  • 9,606 POSTS
What do you mean by "goes out", does the transmission have any forward gears, is reverse inoperative?
Apr 27, 2009 at 1:10 AM
CHRIS154
the car drive fine. it just wont go in reverse. is there a certain part that need changed out. Can i change the entire clutch system will that correct the problem
Apr 27, 2009 at 2:27 AM
DOCHAGERTY
  • 9,606 POSTS
No reverse can mean there is a clutch pack that has failed inside the tranny, are you willing to attempt this repair and do you have the resources to complete the task?
Apr 27, 2009 at 4:04 AM
CHRIS154
I want to repair it I have a brand new Lux Clutch kit for the car. will that fix the promblem.
Apr 27, 2009 at 9:28 AM
DOCHAGERTY
  • 9,606 POSTS
You bought a clutch kit for an automatic transmission?
Apr 28, 2009 at 4:27 AM
CHRIS154
yes a clutch kit for an automatic tranmission for a bmw 323I it look like a plate with gears in it.
Apr 28, 2009 at 10:14 AM
DOCHAGERTY
  • 9,606 POSTS
If you have a foot press, a clean room and all the special tools for the rebuilding of the transmission, I would think twice before taking on this project my friend.
Apr 29, 2009 at 4:59 AM
