2000 BMW 323 Recharge airconditioning
2000 BMW 323
JCDORSEY
Air Conditioning problem
2000 BMW 323 6 cyl Two Wheel Drive Automatic
Where do I recharge the air? There is a hookup in front of the engine and there is a hookup in the back next to the firewall, which one do I use?
Aug 19, 2008 at 7:27 AM
DOCHAGERTY
  • 9,606 POSTS
If you are not a licensed A/C technician then I do not recommend trying to perform repairs to the A/C system. You should seek out a professional to assist you in this task due to the safety concerns. The two ports you have located will both be used to facilitate evacuating and charging the system. One of the fittings is the low side and the other is the high side. Special skills, certification and tools will be required to complete this task. If you wish to continue please repost, if not and you choose to seek out professional help, cheers♥
Aug 19, 2008 at 11:55 AM
