2000 BMW 323 Lower control arms
2000 BMW 323
GNOOTS
Suspension problem
2000 BMW 323 6 cyl Two Wheel Drive Automatic
Can't get outer ball joints out! Have removed nut and have tried joint fork with no luck. Any tips?
Jun 15, 2008 at 4:24 AM
DOCFIXIT
  • 18,828 POSTS
Wedge the fork in real tight then take a hammer I prefer a small 4lb sledge. Then smite the spindle ie the thick metal between the nut and joint. If this does not work get a torch heat the spindle and smite again.
Good luck and smite away
Jun 15, 2008 at 4:39 AM
