2000 BMW 323 fan
105,000 MILES • 6 CYL • 2WD • MANUAL
GLENN2TONE
coolant fan runs all the time . changed out senser did not help
Aug 20, 2009 at 11:05 PM
DOCHAGERTY
  • 9,606 POSTS
The auxiliary fan is controlled by a device called a final stage. It is controlled digitally and can and does often fail in a "catastrophic" fashion. The failure should first be properly diagnosed, which is impossible for me to do from cyberspace and may require some special equipment. The final stage is built into the fan and cannot be had as an individual part.
Aug 21, 2009 at 4:57 PM
