2000 BMW 323 Dash lights
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
COWGIRLV
  • 5 POSTS
I have 2 lights coming on in my car - sporadically - started about 1-2 months ago:
Oil light - it is yellow
Coolant - it is yellow
The oil light comes on for about 10-15 sec when I start up the car. It will then go off. I had the level checked when it started, but the level was fine - it was right at the max line. I just had the oil changed about 2 weeks ago - it did not make a difference.
The coolant light also started coming on around the same time. This light only comes on after I have been driving awhile. It will go on and off.
The temperature gauge shows normal (right in the middle) at all times.
Any ideas? Thanks!
Nov 13, 2008 at 5:57 AM
COWGIRLV
  • 5 POSTS
The coolant level has been checked as well - but it is fine.
One other thing:
My power steering fluid level has been dropping. It has been filled up twice in the past 3 months or so. There is no leak on my garage floor. When I had my oil changed, they were looking for a leak, but nothing was happening.
Thanks.
Nov 13, 2008 at 6:02 AM
DOCHAGERTY
  • 9,606 POSTS
The oil level sensor is commanding the light on. Replacement is not needed but I can see where this could be very irritating. The P/S is seeping fluid and you say they cant find it, the P/S hoses are likely to need closer inspection by someone who knows BMW. The coolant level warning is possibly a faulty sensor, if the level is ok and there are no leaks then I would not worry too much.
Nov 13, 2008 at 7:09 AM
COWGIRLV
  • 5 POSTS
Cute cat!
I'll have it checked out!
Nov 13, 2008 at 7:21 AM
