2000 BMW 323 air bag lite on solid
2000 BMW 323
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
SARIN VON
It happened several times, and the last time I went to the BMW dealer: the problem was a switch in the driver seat belt buckle. I would like to know how to open the buckle shell to verify swith or sensor in it, and do I need to remove power cable from the battery because of possible airbag activation. There must be latches in the buckle holding the shell, but I could not find them. Thank you in advance for your tips.
May 16, 2009 at 3:04 AM
DOCHAGERTY
  • 9,606 POSTS
The issue with the SRS system usually has to do with the wiring more than the latch. There seems to be a concern regarding the system functionality process, the warning light is on for some fault and that fault may be system failure or just a glitch in the fault history recorded for an issue that no longer exists.
May 20, 2009 at 3:05 PM
