It happened several times, and the last time I went to the BMW dealer: the problem was a switch in the driver seat belt buckle. I would like to know how to open the buckle shell to verify swith or sensor in it, and do I need to remove power cable from the battery because of possible airbag activation. There must be latches in the buckle holding the shell, but I could not find them. Thank you in advance for your tips.
SPONSORED LINKS
Saturday, May 16th, 2009 AT 10:04 AM
