2000 BMW 323 Access to door lock components
2000 BMW 323
CVARGASJR
Interior problem
2000 BMW 323 6 cyl Two Wheel Drive Automatic
Do I need to lower/remove the window glass from my 2000 323ci to work on the locks? If so, should the window adjustments be made by a pro, or can I do this myself?
Jun 17, 2010 at 11:30 AM
DOCHAGERTY
  • 9,606 POSTS
What work on the locks are you doing?
Jun 19, 2010 at 10:34 AM
CVARGASJR
Both front doors. The drivers requires several tugs to open ( I believe sometimg isn't catching properly) and the passenger side only occasionally electronically unlocks, although I can hear the mechanism working through the door
Jun 19, 2010 at 1:08 PM
DOCHAGERTY
  • 9,606 POSTS
Is the problem opening the doors once they're unlocked, or when you are unlocking them electronically?
Jun 19, 2010 at 1:22 PM
