1999 BMW 323 sway bar link torque
1999 BMW 323
FIRECOMCRT
Suspension problem
1999 BMW 323
what is the sway bar link torque for a 99 bmw 323 i. i am replacing two of them.
Jan 19, 2009 at 2:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Tighten the bushing mounts to 16 ft. lbs. (22 Nm).
On models with strut mounted links, install the stabilizer bar links and torque the nuts to 43 ft. lbs. (59 Nm) with the wrench flats parallel to the edges of the bar.
On models with control arm mounted links, tighten the link-to-control arm locknut to 30 ft. lbs. (42 Nm).
Thanks for using 2CarPros.com!
Jan 19, 2009 at 2:08 PM
