1999 BMW 323 Electric fan won't turn off and code for radio
1999 BMW 323
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDNAPA
It seems like the electric fan is not turning off. When I look the fan is not moving but it "sounds" like a fan is on. It caused the battery to die.
Also when I replaced the battery, the radio has a code # to turn it on.
Jan 6, 2008 at 4:24 AM
DOCHAGERTY
  • 9,606 POSTS
possibly a failed final stage unit for the fan. try performing a key off draw test with an ammeter to find the draw. that model should be no more than 50 milliamp. As to the radio code issue, BMW has made it difficult to obtain radio codes for their radios. there is a process that requires submitting a case file and can only be done by the dealer. I have taken to replacing the old BMW radios with more modern equipment. See crutchfields.com for a place to start, or go to the dealer.
Jan 13, 2008 at 2:24 AM
