1999 BMW 323 Acceleration
1999 BMW 323
HELPNEEDED
Engine Performance problem
1999 BMW 323 Manual 91,000 miles
I am having acceleration issues. For example when I am on the highway and I go to pass someone my car is not accelerating properly. It is hesitating before it will engage and give the boost of power needed to pass the car. I have recently replaced the oxygen sensor, intake boot and air filter. I am getting ready to replace the camshaft sensor and the fuel filter. Do you have any suggestions on what may be causing this issue?
Jul 14, 2010 at 2:52 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jul 14, 2010 at 6:50 PM
