1998 BMW 323 fault code P0740
JMULLEN17
1998 BMW 323 Automatic
how would i go about checking a torque converter clutch circuit malfunction?
May 15, 2008 at 1:33 PM
DOCHAGERTY
  • 9,606 POSTS
It may have something to do with wiring that is inside the transmission or the solenoid for the TCC is out of tolerance. This may require removal of the oil pans and inspection of the internal harness and a resistance check of the TCC solenoid. Be sure to replace the filter too. If you need more help let me know.
May 22, 2008 at 1:27 PM
