1998 BMW 323 fault code
JMULLEN17
1998 BMW 323 6 cyl Automatic
the check engine light came on and i got the follwing codes from my reader
11F5 & 11F6 which are secondary air system flow too low cyl 1-3 & 4-6 what could be the problem?
May 15, 2008 at 7:35 AM
DOCHAGERTY
  • 9,606 POSTS
It might be either the vacuum hose to the secondary air injection valve is cracked or the secondary air pump is not up to par. I have seen the pumps set faults even though they seem to run just fine.
May 22, 2008 at 1:32 PM
