1998 BMW 323 engine will not start
70,000 MILES • 6 CYL • 2WD • MANUAL
BARRYF45
i turn the key and there is just a noise? no engine turn at all
Dec 6, 2008 at 10:25 PM
  • 75,988 POSTS
Have the battery tested if okay make sure its cleaned and properly tightened then try again. Don't work probable causes could be ignition switch/clutch switch/starter relay and starter itself-
Dec 6, 2008 at 10:43 PM
