1995 BMW 323 clunck when i brack
1995 BMW 323
114,000 MILES • 6 CYL • FWD • MANUAL
IAN LALLY
i have recently noticed that when i brack going foward that i get a cluck every time i apply the bracks The cluck is coming is coming from the front non drivers side I have had the abs system checked and that is ok It does not do it in the wet I have also changed the caliper and everything is tight hte caliper is from a 3 series but not off a 323i
Oct 9, 2009 at 10:17 AM
DOCHAGERTY
  • 9,606 POSTS
Inspect the lower control arm bushings. They are often the cause of the issue you are having.
Oct 9, 2009 at 9:29 PM
