1988 BMW 323
22,869 MILES • 6 CYL • 2WD • MANUAL
DIANA JACKSON
I in replaced the engine in April the engine gaUAGEs still go read hot an go up to the red. I took it back and the mechanic said I needed a cluch fan so I brought one while my dad was begin to take it of he found that the bolts were lose to the c-fan he tight them still run-hot. My dad replaced the thermostat, the sensor on the engine replaced that fan switch, replaced all the fuses. It still running hot it take about five mins to rise. My question is what would make this car run hot after all been done. also when an engine has been replaced with another used engine what should the mehanic replaced on that used engine before returning it to the customer.
Jul 3, 2010 at 8:23 AM
DOCHAGERTY
  • 9,606 POSTS
It seems the root cause of the over-heating has not been found. Is the radiator sound, or is it full of "mud" and does it have cold spots? Did you bleed all the air from the system through the bleeder valve? Was the replacement motor a known good motor? I await your response.
Jul 3, 2010 at 8:37 AM
