320I 2004 replacing front ball joint at 45,000km's
2004 BMW 320
SPOTTYB
Hi!
After the Stability control light coming on only at cold start, it finally came on and stayed on. The local repairer is relacing something on the central steering under warranty (as should be - car is less than 3 years old)
But they have also found a problem with the "ball and arm" joint on the front drivers side. He also called it a "basher"? He said that this is a part that is normally requiring replacement at 60-70,000 kms.
My question is whether I should fight this replacment (they are charging me) or should this be a manufacturer warranty issue, considering milage and age of car? This car is only city driven (short trips under 40kms)
Jul 24, 2007 at 6:53 PM
DOCHAGERTY
  • 9,603 POSTS
I am not sure of what the repair technician is talking about. An '04 car should still be covered under warranty.what is a basher? post pictures if you can of the failed items.Are you posting this from England or from a British sovereignty?I am a BMW master technician in California and your car may not fall under the same rules this side of the pond.
Jul 26, 2007 at 5:21 PM
