2005 BMW 320 change spark plugs
2005 BMW 320
55,000 MILES • 4 CYL • 2WD • MANUAL
BRIANG1
i can not get cover off to change plugs as it seems to be sticking at back
there are no nuts to loosen and i thougth would be easy just to remove oil filler cap and pull out but no
i tried removing pollem filter and loosened hoses that run over top but there seems to be a lip at back catching and i didnt want to pull case it broke and it doesnt just lift up
i would be grateful if you canadvise me correct way to remove cover so i can change spark plugs
thanx again
Mar 9, 2010 at 1:32 AM
DOCHAGERTY
  • 9,606 POSTS
Pop the two small covers loose, then the 10mm nuts come off, and there you have it.
Mar 9, 2010 at 2:40 PM
